Inleiding
University Tear Down of the LG KF700 by Richard 'Bootstrap Bill' Turner, Estyn 'Indiana' Jones, David 'Adolf' Hilliker and Elani 'Cupov' Kafa!
Wat je nodig hebt
All the circuit boards are attatched with wiring which makes it hard to remove all the components without damaged to the phone. To remove properly you need to remove to solder holding the wiring to other componets, or you can just cut the wires.
The boards are held down with small screws, simply remove the scres to access the underside of the circuit boards.
Finally the screen being made up of several layers can also be separated.
Unhook the final chip carefully to allow a protecting layer to be removed.
Then slowly pull the chip off itself and the four layers will then be easily separated with a steady hand and a small pair of tweezers.
