Ga door naar hoofdinhoud
Wat je nodig hebt
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je LG G7 Thin Q te repareren, gebruik onze reparatiehandleidingen.
    Laatste gedachten
    • Lots of components are modular and can be replaced independently.
    • The battery can be replaced, but adhesive and a glued-on rear panel make it unnecessarily difficult.
    • Front and back glass make for double the crackability, and strong adhesive on both makes it tough to access the internals for any repair.
    • Screen repair, the most common type repair, is not prioritized, requiring an almost complete disassembly while battling tough adhesive.
    Repareerbaarheidsscore
    4
    Repareerbaarheid 4 op 10
    (10 is gemakkelijkst te repareren)
9Gids Commentaar
Good luck to you.
coco - Antwoord
哈哈哈哈哈哈哈哈哈哈哈哈
coco - Antwoord
wanted close up pictures
Genesis Amadeus - Antwoord
when the back glass cover is replaced after it is cracked and then pried off, how do you achieve “water proof” again”? Thank you
Richard W - Antwoord
You have to install new adhesive.
segin2005 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 187
Altijd: 44,903
