Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je LG G Watch R te repareren, gebruik onze reparatiehandleidingen.
  1. LG G Watch R Teardown, Front and Back: stap 1, afbeelding 1 van 2 LG G Watch R Teardown, Front and Back: stap 1, afbeelding 2 van 2
    • LG G Watch R assembly.
  2. LG G Watch R Teardown, Removing the back cover: stap 2, afbeelding 1 van 2 LG G Watch R Teardown, Removing the back cover: stap 2, afbeelding 2 van 2
    • First remove the watch band using a small flat screw driver to compress the spring loaded pin.
    • Remove the four T4 torx screws (Green).
    • Carefully pry the base off using a thin flat screw driver
  3. LG G Watch R Teardown, Removing the Board: stap 3, afbeelding 1 van 2 LG G Watch R Teardown, Removing the Board: stap 3, afbeelding 2 van 2
    • Disconnect the four electrical connectors from the board
    • Orange - Battery connector
    • Blue - button and charging connector
    • Green - Backlight
    • Purple - O-LED Controller + Mic
    • Remove the three phillips screws securing the board down. Then lift the board off the base
  4. LG G Watch R Teardown, The Battery: stap 4, afbeelding 1 van 2 LG G Watch R Teardown, The Battery: stap 4, afbeelding 2 van 2
    • The battery is below the board.
    • The battery can easily be pried out using a small flat head screwdriver.
  5. LG G Watch R Teardown, Battery housing: stap 5, afbeelding 1 van 1
    • Using a small pliers and a small flat screwdriver the battery housing comes out easily.
  6. LG G Watch R Teardown, P-OLED Panel: stap 6, afbeelding 1 van 3 LG G Watch R Teardown, P-OLED Panel: stap 6, afbeelding 2 van 3 LG G Watch R Teardown, P-OLED Panel: stap 6, afbeelding 3 van 3
    • Pictures of the front and back of the 1.3" P-OLED.
    • The screen is glued in.
Dustin Richards
332 Reputatie
1 Handleiding geschreven
8 opmerkingen
Is there a wifi antenna inside the LG G watch R?
Fernando Perez - Antwoord
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Mark Fortune -
Are there differences between the UK as US G Watch R?
James Kemble - Antwoord
Where could I find a battery for replacement?
Thanks in advance.
Fab - Antwoord
Any tips for what to check if the touchscreen turns on but is non-responsive ?
richard - Antwoord
hi, have you found a solution? on my watch everything works except the touch screen….when you touch it or move your arm it turns off….if you put your palm on the screen istead of turning off it goes on
Tony Forandroid -
Ha lezárt a kijelző de nem tudom a kódot lehet valamit tenni?? :(
ndavidattila - Antwoord
Hi could you post the watch cradle wiring diagram.
I bought non original cradle, and it only can charge, no data connection
Ippo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 20,243
