Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Kyocera Oystr te repareren, gebruik onze reparatiehandleidingen.
  1. Kyocera Oystr Teardown, Removing the battery: stap 1, afbeelding 1 van 3 Kyocera Oystr Teardown, Removing the battery: stap 1, afbeelding 2 van 3 Kyocera Oystr Teardown, Removing the battery: stap 1, afbeelding 3 van 3
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Teardown, Removing screws from screen: stap 2, afbeelding 1 van 3 Kyocera Oystr Teardown, Removing screws from screen: stap 2, afbeelding 2 van 3 Kyocera Oystr Teardown, Removing screws from screen: stap 2, afbeelding 3 van 3
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Teardown, Exposing internal components: stap 3, afbeelding 1 van 3 Kyocera Oystr Teardown, Exposing internal components: stap 3, afbeelding 2 van 3 Kyocera Oystr Teardown, Exposing internal components: stap 3, afbeelding 3 van 3
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Teardown, Removing metal cover: stap 4, afbeelding 1 van 1
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Teardown, Screen removal: stap 5, afbeelding 1 van 3 Kyocera Oystr Teardown, Screen removal: stap 5, afbeelding 2 van 3 Kyocera Oystr Teardown, Screen removal: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Teardown, Completing the repair: stap 6, afbeelding 1 van 1
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
David
24 Reputatie
2 handleidingen geschreven
UW Stout, Team 5-7, Zhou Fall 2011 Lid van UW Stout, Team 5-7, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G7
2 Leden
4 handleidingen geschreven
2 opmerkingen
where do I get a new screen?
LARS ANDERSEN - Antwoord
where do i get a new screen
thanks
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 4,353
