Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je KAMBROOK 1.7L BPA Free Kettle te repareren, gebruik onze reparatiehandleidingen.
  1. KAMBROOK 1.7L BPA Free Kettle Teardown, KAMBROOK 1.7L BPA Free Kettle: stap 1, afbeelding 1 van 1
    • Put the device on the table.
    • CAUTION: Make sure the cord is not plugged into the outlet in order to prevent electrocution.
    • CAUTION: Make sure there is no water inside the kettle.
  2. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 2, afbeelding 1 van 1
    • Take off the handle cover and the button on it.
  3. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 3, afbeelding 1 van 1
    • Turn the device upside down and screw down the screws.
  4. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 4, afbeelding 1 van 1
    • Take the bottom cover off .
  5. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 5, afbeelding 1 van 1
    • Pry down the fixed black circle with a screwdriver
    • Caution: Be careful of the tension.
  6. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 6, afbeelding 1 van 1
    • Pry a slit between the kettle body and metal guy with hammer and screwdriver slowly.
    • Cut the rubber band in two halves and take them off.
    • Finally, take the metal guy off.
  7. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 7, afbeelding 1 van 1
    • Turn the device back to the upside.
    • Use a screwdriver to open the top cover.
  8. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 8, afbeelding 1 van 3 KAMBROOK 1.7L BPA Free Kettle Teardown: stap 8, afbeelding 2 van 3 KAMBROOK 1.7L BPA Free Kettle Teardown: stap 8, afbeelding 3 van 3
    • After you open the top cover, screw down 2 screws at the bottom of it, then you can get the whole cover off easily.
    • Caution: there have some components inside. DO NOT LOSE THEM!
  9. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 9, afbeelding 1 van 1
    • Now focus on the charging base part.
    • Put that on the table.
  10. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 10, afbeelding 1 van 1
    • screw down three screws off in the middle.
  11. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 11, afbeelding 1 van 1
    • Remove 3 white rubber mat with tweezers.
    • Screw down three screws off below rubber mats.
    • The kettle is now fully disassembled.
  12. KAMBROOK 1.7L BPA Free Kettle Teardown: stap 12, afbeelding 1 van 1
Teardown Group 4
205 Reputatie
1 Handleiding geschreven
Één opmerking
why? …………………………
Tatertot - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 649
