Gereedschappen die in deze demontage worden gebruikt
Inleiding
In this teardown, i will disassemble a dead IBM Travelstar DJSA-220 20 GB hard drive which was in a PowerBook G3 Firewire.
Deze demontage is geen reparatiehandleiding. Om je IBM Travelstar DJSA-220 2.5" te repareren, gebruik onze reparatiehandleidingen.
  1. My Victim: a dead IBM Deathstar DJSA-220 20.00GB ATA/IDE 5V 500mA
    • My Victim: a dead IBM Deathstar DJSA-220
      • 20.00GB ATA/IDE
      • 5V 500mA
      • 4200RPM
      • Original Apple OEM!
    • Let's remove the 7 T6 screws!
  2. The disc surface is mirror-like. You can even see my iPhone 3GS! Parts Of The Device
    • The disc surface is mirror-like. You can even see my iPhone 3GS!
    • Parts Of The Device
      • Heads.
      • Head Motor
      • A little bag that absorbs humidity.
  3. Turn the disc over and remove the 7 T4 screws. Then comes the logic board. The black tape is only foam. It doesn't stick.
    • Turn the disc over and remove the 7 T4 screws.
    • Then comes the logic board.
    • The black tape is only foam. It doesn't stick.
    • Contacts for data transfer and head control
    • Contacts for motor power
    • If my scanner wants to work again, i'll post a high res scan of the board.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  5. You now see the back, without the logic board.
    • You now see the back, without the logic board.
    • Heads connector, transfers head-moves commands and data to store and read
    • Motor connector, brings power to move the discs at 4200RPM
  6. Let's attack the inside! remove the two T6 screws.
    • Let's attack the inside!
    • remove the two T6 screws.
    • This piece is a powerful magnet!
    • This is a PCB with a ribbon cable sticked on it
    • Remove the two T6 screws.
    • The screw is on the back, T6 too.
    • I was unable to remove that T8 screw that holds the platters. They keep turning with my screwdriver and i couldn't block it strong enough.
  7. The head with its connector.
    • The head with its connector.
  8. Done!
    • Done!
    • The Screws:
      • 7 T4 screws.
      • 13 T6 screws.
      • 1 T8 screw
    • There are more screws in this hard disc than in a new MacBook!
    • Thank you for reading my first teardown :-)
joelc
216 Reputatie
1 Handleiding geschreven
is there a replacement for this drive, mine just went bad...
julie - Antwoord
Hi, of course, there is! Any 2.5'' ATA hard drive should fit. Beware, some computers have a 128GB capacity limit.
joelc - Antwoord
is there anything reusable from the parts aside from the magnets? can you help me figure it out where I could probably use them?
Sheena - Antwoord
To be honest, not much. If the logic board is fine, you could keep it just in case a same model drive went bad on this side. The screws may be useful if you are dealing with small electronic devices. But for sure, the most interesting part is that strong magnet.
joelc -
Do you happen to know where I can find drivers to get this hard drive to work on my win 7 pc? I need to extract some data from it, thank you in advance
Ville Ahonen - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 8
Afgelopen 7 Dagen: 29
Afgelopen 30 Dagen: 105
Altijd: 34,481
