Inleiding
Disassembly outline
- Battery
- Hard Drive
- Optical Drive
- Memory Cover
- RAM Memory
- Keyboard/Trackpad/Top Cover
- Mini-PCI Slot
- Wi-Fi Card
- Internal Battery
- Display
- Side Bezel
- Video Card / Fan
- Processor
- Video Card / Fan
- Metal Casings
- Plastics
- Motherboard
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Removing the battery
Unplug the power cable before removing the battery.
Slide the 2 sliders on the under side of the laptop to the unlock position, as shown.
Grasp the battery and pull it straight out - not at an angle.
Removing Memory Cover/Replacing RAM
Unscrew the pictured screwed holding the memory cover in place.
Pry the cover open carefully (flathead screwdriver might help)
To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up. -picture of RAM inside -
Pull the stick out carefully. - Picture of the RAM stick -
Removing Rear Cover
Unscrew the rest of the screws on the underside of the T42.
Unscrew the 4 screws on either side the rear end of the laptop.
Note: for ease of reassembly, keep track of which screws go where.
[ a line-drawing version is included so it can be printed and screws can be taped on ]
I wouldn't start with a complete removal of all screws. The IBM/Lenovo hardware manual shows which screws to remove to get to what part.
Manual is at http://download.lenovo.com/ibmdl/pub/pc/....
Removing Keyboard and Trackpad
Flip the laptop over and open the display carefully - the keyboard, palm rest and bezel will be loose.
Maneuver the palm rest away from the keyboard carefully, both the keyboard and palm rest/trackpad will come off together.
**WARNING** Both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
Removing the Display
To remove the display, unscrew the screws holding it down. Along with the one pictured, there is another one on the top right edge.
Carefully unplug the its connection with the motherboard.
Now it will be free to move. Carefully maneuver it out.
Removing Fan
Unscrew the three shown screws, then unplug its connection with the motherboard.
**Since both the processor and graphics processor unit are attached to this fan with thermal paste, removing the fan might require some force and a flathead screwdriver to separate the paste from the fan.
Removing Processor
After removal of the fan, you have access to the processor. Locate its locking mechanism.
Use a flat head screwdriver and twist it carefully to the "unlocked" position.
Carefully pull the processor out.
***CAUTION - If replacing the processor, make sure the small arrow on the corner aligns with socket.
Removing Metal Casing
Unscrew the Philips head screws as shown
It is attached to the smaller black plastic piece below it - carefully maneuver both of them out at the same time.
To reassemble your device, follow these instructions in reverse order. Remember when reassembling to apply a thin layer of thermal compound on the CPU block.
16 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
Great guide on how to take apart a computer!
