Ga door naar hoofdinhoud
Deze demontage is aan de gang – Herlaad regelmatig om de laatste wijzigingen te zien!
Wat je nodig hebt
  1. Hamilton Beach "Keep Warm" Toaster 22811 Teardown, Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 1, afbeelding 1 van 1
    • Unplug toaster from wall.
    • Do not take apart a toaster that is plugged in.
    • If toaster has been used, lay down paper towels or work outside to avoid making a mess.
  2. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 2, afbeelding 1 van 1
    • Remove crumb tray from bottom of toaster.
  3. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 3, afbeelding 1 van 1
    • Remove these 7 screws from bottom of toaster.
  4. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 4, afbeelding 1 van 1
    • Remove bread lifter/toast booster by prying it off. The plastic piece snaps over the metal part during assembly. Use a flat-blade screw driver from the side to widen the gap in the plastic clip while pulling the plastic handle out. Done right the handle can later be reassembled securely.
  5. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 5, afbeelding 1 van 1
    • Disconnect the two circuits by unplugging the wires shown. This can be done by pressing the lever on the crimps. Then the shell can be pulled off from the rest of the toaster.
  6. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 6, afbeelding 1 van 1
    • Remove these 2 screws.
  7. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 7, afbeelding 1 van 1
    • Remove this screw.
  8. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 8, afbeelding 1 van 2 Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 8, afbeelding 2 van 2
    • Remove these 4 screws.
  9. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 9, afbeelding 1 van 1
    • Pull apart toaster components. If power cable needs to be removed or adjusted, unscrew the screws circled.
  10. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: stap 10, afbeelding 1 van 1
    • If the circuit for the buttons and shade selector needs to be removed, unscrew these 4 screws.
Alexander Yazdani
846 Reputatie
3 handleidingen geschreven
Cal Poly, Team S18-G1, Livingston Spring 2018 Lid van Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 3,248
