Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Camera te repareren, gebruik onze reparatiehandleidingen.
  1. GooGo Teardown, GooGo Teardown: stap 1, afbeelding 1 van 2 GooGo Teardown, GooGo Teardown: stap 1, afbeelding 2 van 2
    • Opening the device by simply separating the two halves with a plastic prying tool.
Bijgevoegde documenten
jerome cintas
179 Reputatie
1 Handleiding geschreven
7 opmerkingen
I cant see where the camera is, is it a lense focusing onto a ccd on the motherboard???
Steve Rock - Antwoord
Hi Jerome,
There is a small brass thread on the side of the Googo Camera,
Do you know what it is for.
many Thanks Dave Gould dave.gould@ymail.com
David Gould - Antwoord
hi .. if there a place to solder in a more powerful antenna, would that even help?
sadstory - Antwoord
Do you know how to reset the password of the camera by hardware?
Hugo Uchida Frausto - Antwoord
My phone is showing error in camera can't be opened
Sib Gat - Antwoord
sorry guys for some reason i never saw your comments before now...
the camera is located behind the bottom adhesive in the picture. it is a separated pcb.
i have no idea what the brass thread is for..
for the password, no idea how to reset it, i must admit i haven't touched the camera for a while...
sib gat, sorry i have no idea what the problem might be. check that you are on the googo's wifi network, and that settings for the wifi are ok.
Again, sorry i just received sib gat's comment notification, i don't remember seeing any other notification..
Jerome
jerome cintas - Antwoord
Man i’m wanting to purchase a googo cam but all the feedback I find seem to be negative. not one positive. Are all these cameras ,hmm, not very good or is it just the good ones haven’t left any feedback. Really wanted on of these but having second thoughts now
Eric K - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 8,077
