Inleiding
I'd reccomend repasting the gpu if you're going to be cleaning it
Wat je nodig hebt
To strip down the GPU you'll need a Phillips #1 screwdriver
Optionally if you want to replace the fan you'll also need a Phillips #000 screwdriver
Remove 12 screws joining the heatsink to the GPU (Phillips #1)
Carefully "unfold" the heatsink as to not rip the fan connector
Disconnect the fan
Unpeel a piece of the tape that's holding down the cable
Fish the connector through the hole
