Inleiding
Hier wird ein Game Boy Advance zerlegt
Wat je nodig hebt
Drücke die Klinke am Akkudeckel nach unten und ziehe ihn heraus.
Entsperre den LCD Stecker indem du die beiden grauen Laschen an den Seiten mit einem Spudger/Fingernagel/Pinzette in Richtung Oberkante der Platine ziehst.
Wenn er entsperrt ist sollte das Flachbandkabel zum LCD leicht herauskommen und kann mit den Fingern oder der Pinzette gelöst werden.
Guide does not indicate that the ribbon cable port should be UNLATCHED before attempting to remove the ribbon cable, I strongly suggest revising this as someone unfamiliar with these style of ports may assume that the ribbon cable is a compression fit and just needs to be "pulled" free of the port.
This is a terrible idea that will potentially result in tearing the ribbon! Please consider revising guide to add a step to indicate the proper method/detail for unlatching the LCD ribbon port! Thanks :)
Hebe das LCD mit einem Spudger aus dem Vorderteil. Setze den Spudger direkt in den Spalt links vom Steuerkreuz.
This is a BAD place to pry on a functioning LCD. I used this exact method, slowly and carefully, and my LCD shattered.
Instead, remove the lens (it’s worth it to sacrifice the lens adhesive to save your LCD), and gently and slowly press with a gloved thumb on a corner to push it through from the front of the Game Boy. Let the adhesive release itself, don’t force it. If the room is super quiet, you should be able to hear a faint peeling sound, even if you can’t see anything moving. That means you’re doing it right; just wait and it will release.
Actually you can just pry under the ribbon cable. The LCD has a metal frame there that allowed me to slowly and carefully pry from that point without (re)breaking my LCD.
Yep. Same thing just happened to me :(
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
7 opmerkingen
I dont understand. The items in “Tools featured in this teardown" is different from the tools written on the article e.g. Y0 in “featured" but Y1 in the “article”.
Great guide. My dumb ass didn’t see the screws holding the circuit board to the front shell lmao
What is the cpu
I am having difficulty determining the size of the Tri-Point screws used on the Game Boy Advance. As a previous commenter noted the screw driver listed as “Tools Featured in this Teardown” shows a size of Y0, but in the text of the teardown it shows Y1. Can someone please clarify?
How do you remove the CPU and SRAM chips?
