Inleiding
Remove EVF from Fujifilm X30, and get a teardown of EVF lenses
Wat je nodig hebt
Follow disassembly instructions from disassembly guide through step 17
unscrew 2 philips screws.
Slide the EVF to remove it. Becareful "play" button will come out too.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
disassembly plastic cover
unscrew plastic wheel.
Becareful not to loose the little metal ball
Working on a magnetic mat can be handful
when re-assembling:
put the first plastic wheel on place
Drop the ball in the hole, and put the spring over it
Then screw the second plastic wheel over it
To remove lens block, you have to push the 2 metal rods from one side to the other. The rods have one end thinner than the other
Now you can remove every lens in order to clean them from dust or humidity
When re-assembling, there's only one way to get them back in, so keep track of lenses order and direction when removing each one of them. Or wou'll have to try many times to comlete the puzzle.
