Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Franklin MWD-460A te repareren, gebruik onze reparatiehandleidingen.
  1. Franklin MWD-460A Teardown, Fully Assembled: stap 1, afbeelding 1 van 2 Franklin MWD-460A Teardown, Fully Assembled: stap 1, afbeelding 2 van 2
    • Here is the fully assembled Franklin MWD-460A Electronic Dictionary.
  2. Franklin MWD-460A Teardown, Battery Compartment: stap 2, afbeelding 1 van 3 Franklin MWD-460A Teardown, Battery Compartment: stap 2, afbeelding 2 van 3 Franklin MWD-460A Teardown, Battery Compartment: stap 2, afbeelding 3 van 3
    • On the back of the case, locate the battery compartment, its cover, two grooves, and the tab (which locks the cover in place).
    • Release the cover by pulling down on the tab with a fingernail.
    • While holding the tab down, insert the opening tool into one of the grooves and gently pry the cover off.
  3. Franklin MWD-460A Teardown, Separating the Panels Part 1: stap 3, afbeelding 1 van 3 Franklin MWD-460A Teardown, Separating the Panels Part 1: stap 3, afbeelding 2 van 3 Franklin MWD-460A Teardown, Separating the Panels Part 1: stap 3, afbeelding 3 van 3
    • Locate the battery grooves.
    • Remove the batteries by inserting the prying tool into the grooves (sliding it underneath the batteries).
    • Locate the one screw inside the battery compartment, loosen it, and remove it.
  4. Franklin MWD-460A Teardown, Separating the Panels Part 2: stap 4, afbeelding 1 van 3 Franklin MWD-460A Teardown, Separating the Panels Part 2: stap 4, afbeelding 2 van 3 Franklin MWD-460A Teardown, Separating the Panels Part 2: stap 4, afbeelding 3 van 3
    • Locate the six tabs holding the two panels together along the sides.
    • Insert the prying tool into each of the six grooves and gently separate each tab from its insert on the other panel.
    • Finally, separate the panels from one another.
  5. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: stap 5, afbeelding 1 van 3 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: stap 5, afbeelding 2 van 3 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: stap 5, afbeelding 3 van 3
    • Locate the three screws holding the upper circuit board in place.
    • Loosen and remove the three screws.
    • The screw in the top right corner is also holding a tab in place so remember where it goes.
  6. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1 Continued: stap 6, afbeelding 1 van 1
    • Gently lift the upper circuit board to locate the up/down keypad and remove it.
    • Be careful when moving the upper circuit board as it's attached to the LCD screen and the lower circuit board.
  7. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 2: stap 7, afbeelding 1 van 1
    • Locate the eight screws holding the lower circuit board in place.
    • Gently pull up on the tape to expose the eighth screw.
    • Loosen and remove the eight screws along with their washers.
  8. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: stap 8, afbeelding 1 van 2 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: stap 8, afbeelding 2 van 2
    • Gently lift the two circuit boards (along with the attached LCD screen) away from their case.
    • Now peel the lower keypad from its case.
  9. Franklin MWD-460A Teardown, Full View of Disassembly: stap 9, afbeelding 1 van 1
    • Here is a full view of the disassembled Franklin MWD-460A Electronic Dictionary.
Chris L
1.522 Reputatie
3 handleidingen geschreven
Één opmerking
How can I fix the screen? The letters are so faded. :(
Paola Paniagua - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,157
