Ga door naar hoofdinhoud
FlySky FS-TH9X Teardown Battery Harness
  1. FlySky FS-TH9X Teardown Battery Harness, Battery Harness: stap 1, afbeelding 1 van 1
    • Locate the battery pack on the back of the device all the way at the bottom.
    • Link for the replacement part, Battery Holder
  2. FlySky FS-TH9X Teardown Battery Harness: stap 2, afbeelding 1 van 1
    • Once you located the battery pack, carefully push on the pack and down at the same time to open the back plate.
  3. FlySky FS-TH9X Teardown Battery Harness: stap 3, afbeelding 1 van 1
    • After the back plate is open, the harness battery is accessible.
  4. FlySky FS-TH9X Teardown Battery Harness: stap 4, afbeelding 1 van 2 FlySky FS-TH9X Teardown Battery Harness: stap 4, afbeelding 2 van 2
    • Locate the plug for the battery harness in order to pull it out carefully from where it is plugged.
Conclusie
Jonathan Sanchez
109 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 138
