Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Fitbit Charge HR te repareren, gebruik onze reparatiehandleidingen.
  1. Fitbit Charge HR Teardown, Remove Screws: stap 1, afbeelding 1 van 1
    • Take the 4 Screws out of the Sides you will need a T3 star Screw Driver
  2. Fitbit Charge HR Teardown: stap 2, afbeelding 1 van 2 Fitbit Charge HR Teardown: stap 2, afbeelding 2 van 2
    • You Pry out the Main board you can see the Metal Hooks
  3. Fitbit Charge HR Teardown: stap 3, afbeelding 1 van 1
    • You can Then pull out the Screws from around the Screen
Bradley Nelson
56 Reputatie
1 Handleiding geschreven
8 opmerkingen
Can the battery be replaced?
Rick - Antwoord
Mine was just over a year old (barely out of warranty) when it died. The Fitbit folks were kind enough to replace it anyway once I expressed my displeasure. I'd haggle with them a bit before going the DIY route but I'm definitely keeping my old one for spare parts. Hopefully someone will point out an aftermarket battery source before I need to do that.
fragmasterflash - Antwoord
The screws in mine were Torx T-2, not T-3.
Jake McIvor - Antwoord
The button is stuck in my ChargeHR. I bought the T3 screwdriver and it is too big. Either the screws are T2 or my screwdriver is too much imprecise.
Anyone fixed a stuck button?
Anderson Maciel - Antwoord
it definitely not T3 must be T2
Marc Frederick - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 24,064
