Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Fan te repareren, gebruik onze reparatiehandleidingen.
  1. Fan Teardown, Fan Teardown: stap 1, afbeelding 1 van 1
    • The image displayed to the left of the screen portrays a mobile fan in pristine condition.
  2. Fan Teardown: stap 2, afbeelding 1 van 1
    • The Guard of the fan is detached from its base due to the effectiveness of a screwdriver.
  3. Fan Teardown: stap 3, afbeelding 1 van 1
    • As seen in the photograph to the left, the blade of the fan has been removed from its guard.
  4. Fan Teardown: stap 4, afbeelding 1 van 1
    • The image to the left of the screen displays the guard of the fan conspicuously detached from the fans base. Various screws are spread across the canvas due to their removal.
  5. Fan Teardown: stap 5, afbeelding 1 van 1
    • We have diverted our focus in disassembling components mainly involved with the fans blade and have begun to focus on "tearing down" the fans motor and shaft.
  6. Fan Teardown: stap 6, afbeelding 1 van 1
    • The photograph which lays on the left of the screen displays the process of tearing down the initial motor of the mobile fan.
  7. Fan Teardown: stap 7, afbeelding 1 van 1
    • The casing which covered the interior of the motor has now been removed through the use of a screw to gain access to its interior.
  8. Fan Teardown: stap 8, afbeelding 1 van 1
    • Now that the casing has been removed, we have gained access to the motor's circuit board.
  9. Fan Teardown: stap 9, afbeelding 1 van 1
    • We have removed the circuit board from the shell which enclosed it so we may study it further.
  10. Fan Teardown: stap 10, afbeelding 1 van 1
    • All components of the fan have been disassembled...your task is now complete.
Jeffrey
309 Reputatie
2 handleidingen geschreven
2 opmerkingen
where did you get the fan?
Anrothan - Antwoord
I’m looking for a replacement fan blade for a reco(unireco) df-12ch fan, I can’t seem to find a website that has them to order.
Renata Weir - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 4,394
