Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Gereedschappen die in deze demontage worden gebruikt
Inleiding
The Emporia Vue is a current monitoring system designed to provide residential users insight into their electricity usage.
Deze demontage is geen reparatiehandleiding. Om je Emporia Vue te repareren, gebruik onze reparatiehandleidingen.
  1. The Emporia Vue is not designed to be taken apart. The case must be  damaged to open it up. The red circles indicate where the case is glued together with supports. The red circles indicate where the case is glued together with supports.
    • The Emporia Vue is not designed to be taken apart. The case must be damaged to open it up.
    • The red circles indicate where the case is glued together with supports.
  2. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  3. The following components are on the inside of the case. ESPRESSIF ESP32-WROOM-32U Silicon Labs EFM8 'Busy Bee' Microcontroller
  4. Full IC Identification:
    • Full IC Identification:
    • You may need to enlarge it to view the text.
Steve Willson
217 Reputatie
2 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 742
