Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je DirectPower DE157 Cordless drill-screwdriver te repareren, gebruik onze reparatiehandleidingen.
  1. DirectPower DE157 Cordless drill-screwdriver Teardown, DirectPower DE157 Cordless drill-screwdriver Teardown: stap 1, afbeelding 1 van 2 DirectPower DE157 Cordless drill-screwdriver Teardown, DirectPower DE157 Cordless drill-screwdriver Teardown: stap 1, afbeelding 2 van 2
    • The driver kit.
    • This is a more-or-less no-name cordless screwdriver/drill kit, but its construction more or less matches most of these devices.
  2. DirectPower DE157 Cordless drill-screwdriver Teardown: stap 2, afbeelding 1 van 3 DirectPower DE157 Cordless drill-screwdriver Teardown: stap 2, afbeelding 2 van 3 DirectPower DE157 Cordless drill-screwdriver Teardown: stap 2, afbeelding 3 van 3
    • The charger consist of a standard wallwart, output 14.4V 350mA, along with a little block (weighing nothing at all) to connect to one of the battery packs.
    • To open the charger block, unscrew three #1 Phillips screws.
  3. DirectPower DE157 Cordless drill-screwdriver Teardown: stap 3, afbeelding 1 van 2 DirectPower DE157 Cordless drill-screwdriver Teardown: stap 3, afbeelding 2 van 2
    • After lifting off the bottom, the PCB is exposed, and you can lift it out of the charger block along with the battery contacts. On the PCB we find:
    • A diode to protect against reverse current.
    • An LED and resistor that is on so long as the box gets power.
    • A giant 10 Ohm resistor to slightly current-limit the charge, and across which the green led and resistor are placed -- this will therefore light up as long as significant current passes to the battery.
  4. DirectPower DE157 Cordless drill-screwdriver Teardown: stap 4, afbeelding 1 van 2 DirectPower DE157 Cordless drill-screwdriver Teardown: stap 4, afbeelding 2 van 2
    • One of the two battery packs. To open, remove
    • Four #1 Phillips screws.
  5. DirectPower DE157 Cordless drill-screwdriver Teardown: stap 5, afbeelding 1 van 3 DirectPower DE157 Cordless drill-screwdriver Teardown: stap 5, afbeelding 2 van 3 DirectPower DE157 Cordless drill-screwdriver Teardown: stap 5, afbeelding 3 van 3
    • After removing the screws, turn right side up again and lift off the plastic cover, exposing 12 NiCd cells in a string, and nothing else.
    • Note that there is room on the right side for three more cells, which would make a 18V battery pack.
    • Especially cheaper makers usually have versions for 7.2V/9.6V/12/14.4/18V all using the same plastic, just more or less cells and a different motor.
Jasper
136 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 2,461
