Ga door naar hoofdinhoud
Deze demontage is geen reparatiehandleiding. Om je Dewalt Impact driver DCF840 te repareren, gebruik onze reparatiehandleidingen.
  1. Dewalt Impact driver DCF840 Teardown, Complete tool and battery: stap 1, afbeelding 1 van 2 Dewalt Impact driver DCF840 Teardown, Complete tool and battery: stap 1, afbeelding 2 van 2
    • This guide covers the complete tool and battery.
  2. Dewalt Impact driver DCF840 Teardown, Opening the tool: stap 2, afbeelding 1 van 1
    • Remove the 8 screws holding the two halves together.
  3. Dewalt Impact driver DCF840 Teardown, Internal mechanism: stap 3, afbeelding 1 van 2 Dewalt Impact driver DCF840 Teardown, Internal mechanism: stap 3, afbeelding 2 van 2
    • Battery Contacts
    • Potted Circuit
    • Brushless Motor
    • Impact Gearbox
  4. Dewalt Impact driver DCF840 Teardown, Gearbox removed: stap 4, afbeelding 1 van 1
    • With the Gearbox removed we are left with the motor on one side and the light ring on the other.
  5. Dewalt Impact driver DCF840 Teardown, Trigger mechanism: stap 5, afbeelding 1 van 3 Dewalt Impact driver DCF840 Teardown, Trigger mechanism: stap 5, afbeelding 2 van 3 Dewalt Impact driver DCF840 Teardown, Trigger mechanism: stap 5, afbeelding 3 van 3
    • Neutral: Trigger Locked
    • Forward
    • Reverse
    • When selector is neutral this tab keeps the trigger from being depressed
  6. Dewalt Impact driver DCF840 Teardown, Splitting the gearbox/impact section: stap 6, afbeelding 1 van 1
    • Gear box fits into housing as a press fit with two clips. Releasing the two clips allows the gear box to be freed from its housing.
  7. Dewalt Impact driver DCF840 Teardown, Gearbox / Impact section: stap 7, afbeelding 1 van 3 Dewalt Impact driver DCF840 Teardown, Gearbox / Impact section: stap 7, afbeelding 2 van 3 Dewalt Impact driver DCF840 Teardown, Gearbox / Impact section: stap 7, afbeelding 3 van 3
    • Planetary gear set: reduce motor speed and increase torque
    • Splines to gear box case
    • Internal teeth for planetary gear set
    • Spring (hard to see) for impact function: base spins and strikes output drive labeled with blue arrow in last picture
  8. Dewalt Impact driver DCF840 Teardown, Battery: stap 8, afbeelding 1 van 1
    • 20V battery at full charge
    • Nominally around 18.5V
  9. Dewalt Impact driver DCF840 Teardown, Splitting battery case: stap 9, afbeelding 1 van 1
    • Remove four screws to open battery
    • Spring for latch to lock battery into tool
  10. Dewalt Impact driver DCF840 Teardown, Battery details: stap 10, afbeelding 1 van 2 Dewalt Impact driver DCF840 Teardown, Battery details: stap 10, afbeelding 2 van 2
    • 5 cells nominally 3.7V in series.
    • 0V (GND)
    • 12V (likely for LED light ring)
    • 3.7V (not connected to tool)
    • 18.5V
    • 18.5V (main output)
Wieli
2.141 Reputatie
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 46
Altijd: 1,217
