Wat je nodig hebt
Unscrew all 9 screws, with a Philips screwdriver then pry open the back of the Chromebook with a spudger.
Unscrew the 3 screws holding the battery in place and unseat the battery from the motherboard. Be careful when removing the battery as there is a sticker.
Remove these screws and then remove an additional screw securing the black and white connection to the WiFi card.
3 screws on each hinge hold the top screen to the bottom of the Chromebook. Removing these allow you to separate the two halves.
The speakers are the easiest to remove. Simply grab the speakers and gently wiggle them free.
There are 2 types of screws for the mouse pad, The first 3 screws secure the mouse pad itself (these screws have a large flat head).
The other 3 screws secure the mouse pad.
To remove the keyboard stick a screw driver through the 2 holes and push it to pop it out.
In order to reach the screw securing the display, you must first remove the sticker covering the screw.
Once you have removed the screws remove the display cover by peeling it off it is glued on.
Once you have removed the screws, remove the display cover by peeling it off.
To remove the display unscrew the 4 screws then peel away the screen.
To remove the hinges, unscrew 4 screws (2 on each side) then remove them.
5 opmerkingen
thank you my speaker broke this helped me fix it with out getting in trouble
the thing that had the thing were i talked about my speaker was kinda for you. ****(((((kinda)))))****
which ribbon cables control which functionality?
my speaker doesn't work its thing got disconnected at home when I had took the bottom of it out for fun but one of the screws was jammed so I twisted the case thingy and then yanked it and I saw the bottom and it was so cool! but I messed up some things and the speaker doesn't work and luckily I was able to put/screw the bottom back on but some of the screws would go in but won't secure/work and stuff. im just a kid i don't know how to fix it that well. maybe some I could fix but I need a bigger brain and head and I also need to learn more. btw im using/typing on this Chromebook. my teachers and maybe parents know that it is like this... they cared a little like probably %5.5 but they really didn't care. the sub cared 4.9% but teachers cared 0.6%. i dont know what else to say................
