Ga door naar hoofdinhoud
Gereedschappen die in deze demontage worden gebruikt
Inleiding
Tearing down a Cyclops Helios headlamp. Both hardware identification and functionality for the device are discussed.
Deze demontage is geen reparatiehandleiding. Om je Cyclops Helios te repareren, gebruik onze reparatiehandleidingen.
  1. Power off Cyclops Helios before tearing down by pushing the black button until the LEDs no longer emit visible light.
    • Power off Cyclops Helios before tearing down by pushing the black button until the LEDs no longer emit visible light.
    • Black button - circled in red
  2. Using two hands, carefully separate the front panel and back panel of the Cyclops Helios. Front panel - boxed in red Back panel - boxed in blue
    • Using two hands, carefully separate the front panel and back panel of the Cyclops Helios.
    • Front panel - boxed in red
    • Back panel - boxed in blue
  3. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  4. Use a Phillips head screwdriver to remove two screws from the front panel. The two screws fasten the outer enclosure with the inner electronics of the front panel.
    • Use a Phillips head screwdriver to remove two screws from the front panel.
    • The two screws fasten the outer enclosure with the inner electronics of the front panel.
  5. Within the enclosure of the front panel there is a clear plastic lens, and plastic button insert. Both are removable. Clear plastic lens - boxed in red Plastic button insert - circled in blue
    • Within the enclosure of the front panel there is a clear plastic lens, and plastic button insert. Both are removable.
    • Clear plastic lens - boxed in red
    • Plastic button insert - circled in blue
  6. The inner electronics of module of the front panel includes a parabolic mirror, circuit board, and battery holder. Circuit board - boxed in blue Parabolic mirror - boxed in red
    • The inner electronics of module of the front panel includes a parabolic mirror, circuit board, and battery holder.
    • Circuit board - boxed in blue
    • Parabolic mirror - boxed in red
    • Battery holder - boxed in green
  7. Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder. Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder.
    • Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder.
Shaun Koide
161 Reputatie
1 Handleiding geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 631
