Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je MP3 Player te repareren, gebruik onze reparatiehandleidingen.
  1. Cowon iAudio 7 8GB Teardown, Cowon iAudio 7 8GB Teardown: stap 1, afbeelding 1 van 1
    • The device in original condition.
  2. Cowon iAudio 7 8GB Teardown: stap 2, afbeelding 1 van 1
    • Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
  3. Cowon iAudio 7 8GB Teardown: stap 3, afbeelding 1 van 2 Cowon iAudio 7 8GB Teardown: stap 3, afbeelding 2 van 2
    • All parts disassembled. Second photo shows back side of the PCB.
    • As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
    • A Telechips TCC771L as main CPU.
    • A PCF50606HN battery/power management chip.
[deleted]
210 Reputatie
1 Handleiding geschreven
3 opmerkingen
2011music my songs
Tong Thao - Antwoord
Hi! Could you, please, say what the type of display is there?
tikhonte - Antwoord
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
Endre Sutus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 4,344
