Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Casio Watch te repareren, gebruik onze reparatiehandleidingen.
  1. Casio Digital Watch Teardown, Casio Digital Watch: stap 1, afbeelding 1 van 1
    • This is a teardown of a Casio Digital Watch down to the internal circuitry.
    • You will need a small Phillips screwdriver for this teardown.
    Can we convert it into alarm clock with Big sound
    Ramesh marathe - Antwoord
  2. Casio Digital Watch Teardown, Remove the Case: stap 2, afbeelding 1 van 1
    • Carefully remove the four screws on the backside of the watch.
    • You will need an extremely small screwdriver. A screwdriver to repair glasses would work.
  3. Casio Digital Watch Teardown, Gently Push out the Screen: stap 3, afbeelding 1 van 2 Casio Digital Watch Teardown, Gently Push out the Screen: stap 3, afbeelding 2 van 2
    • Press your fingers on the screen and remove the watch from its case.
    • Be sure to save the three buttons that control the watch
  4. Casio Digital Watch Teardown, Remove the Battery Holder: stap 4, afbeelding 1 van 3 Casio Digital Watch Teardown, Remove the Battery Holder: stap 4, afbeelding 2 van 3 Casio Digital Watch Teardown, Remove the Battery Holder: stap 4, afbeelding 3 van 3
    • Remove the Battery Holder surrounding the circuitry of the watch by carefully pulling off each of the four clips.
  5. Casio Digital Watch Teardown, Remove the Battery: stap 5, afbeelding 1 van 1
    • Remove the battery by pulling from the sides to unstick the adhesive.
  6. Casio Digital Watch Teardown, Detach the LCD: stap 6, afbeelding 1 van 2 Casio Digital Watch Teardown, Detach the LCD: stap 6, afbeelding 2 van 2
    • Remove the four plastic pins connecting the LCD and remove the LCD holder
  7. Casio Digital Watch Teardown, Teardown Complete: stap 7, afbeelding 1 van 1
    • This reveals the internal circuitry of the watch, and the teardown is complete.
    Letters blinking problem .what is the solution
    purna Ganga - Antwoord
Cooper
457 Reputatie
2 handleidingen geschreven
Cal Poly, Team 24-6, Green Winter 2015 Lid van Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Leden
15 handleidingen geschreven
2 opmerkingen
This is my Casio 5 alarm tear down. Can u tell me if this has anything on it that u guys didn't do. Please email me at dolphinzpride@gmail.com...
https://linksharing.samsungcloud.com/wQ5...
Skylar Miller - Antwoord
I have casio illuminator dual time watch, it was damaged outerward accidentally , but internal systems r safe. But now its digits r not displaying properly, sometimes digit parts r missing n sometimes fully 888888 r shown
Sarabjeet Singh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 146
Altijd: 12,683
