Ga door naar hoofdinhoud
Deze demontage is aan de gang – Herlaad regelmatig om de laatste wijzigingen te zien!
Wat je nodig hebt
  1. Black and Decker AS150 Steam Advantage Iron Teardown, Examine the Iron: stap 1, afbeelding 1 van 3 Black and Decker AS150 Steam Advantage Iron Teardown, Examine the Iron: stap 1, afbeelding 2 van 3 Black and Decker AS150 Steam Advantage Iron Teardown, Examine the Iron: stap 1, afbeelding 3 van 3
    • Note that the base of the iron is detached from the upper portion where the dials and handle are location.
  2. Black and Decker AS150 Steam Advantage Iron Teardown, Remove all visible screws: stap 2, afbeelding 1 van 3 Black and Decker AS150 Steam Advantage Iron Teardown, Remove all visible screws: stap 2, afbeelding 2 van 3 Black and Decker AS150 Steam Advantage Iron Teardown, Remove all visible screws: stap 2, afbeelding 3 van 3
    • First remove all the large screws that detach the silver hot plate from the plastic piece attached to it. Lift the white plastic piece to reveal the inner workings of the iron (see last photo attached)
  3. Black and Decker AS150 Steam Advantage Iron Teardown, Clear dust off: stap 3, afbeelding 1 van 1
    • This iron was particularly dusty, clear the dust away with a toothbrush or other small brush. The result is shown in the photo; a clean, dust free iron.
  4. Black and Decker AS150 Steam Advantage Iron Teardown, Further Remove Screws: stap 4, afbeelding 1 van 2 Black and Decker AS150 Steam Advantage Iron Teardown, Further Remove Screws: stap 4, afbeelding 2 van 2
    • Remove the smaller screws located near the square(back) end of the iron releasing cords and wires. Also remove little orange rubber gaskets, and white plastic spacers, taking note where everything was. At this point, your iron should be completely disassembled, and should look like the last photo attached.
  5. Black and Decker AS150 Steam Advantage Iron Teardown, Re-assemble: stap 5, afbeelding 1 van 3 Black and Decker AS150 Steam Advantage Iron Teardown, Re-assemble: stap 5, afbeelding 2 van 3 Black and Decker AS150 Steam Advantage Iron Teardown, Re-assemble: stap 5, afbeelding 3 van 3
    • Beginning with the spacers and gaskets, replace these parts where they belong. Then re-install the small internal screws, taking care to reattach the wires and cords with them. Close the white plastic plate onto the metal hot plate and re-attach the larger main screws. Place black dial receptacle into orange slot (as pictured).
Jayda
247 Reputatie
1 Handleiding geschreven
Texas A&M, Team 1-1, Garza Fall 2014 Lid van Texas A&M, Team 1-1, Garza Fall 2014
TAMCC-GARZA-F14S1G1
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 33
Altijd: 5,185
