Ga door naar hoofdinhoud
Deze demontage is aan de gang – Herlaad regelmatig om de laatste wijzigingen te zien!
Wat je nodig hebt
  1. Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: stap 1, afbeelding 1 van 3 Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: stap 1, afbeelding 2 van 3 Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: stap 1, afbeelding 3 van 3
    • Here it is, ready to be torn'd!
  2. Audiovox CD-Radio Teardown: stap 2, afbeelding 1 van 3 Audiovox CD-Radio Teardown: stap 2, afbeelding 2 van 3 Audiovox CD-Radio Teardown: stap 2, afbeelding 3 van 3
    • Pop off the battery cover and remove the 6 C batteries. Keep them though, they might still be good.
    • Unscrew the 4 highly visible screws with the medium size screwdriver.
    • You'll need a longer bit or a different screwdriver for the other 3 holes. I attempted to unscrew it with my bit based driver, but was unsuccessful.
  3. Audiovox CD-Radio Teardown: stap 3, afbeelding 1 van 3 Audiovox CD-Radio Teardown: stap 3, afbeelding 2 van 3 Audiovox CD-Radio Teardown: stap 3, afbeelding 3 van 3
    • Work your way around the edge shown here with your fingers until a crack appears. Then it should be easy to lift the bottom off.
    • Be careful, The bottom is attached by a few wires. I nearly ripped these apart as I removed the bottom of the case.
  4. Audiovox CD-Radio Teardown: stap 4, afbeelding 1 van 3 Audiovox CD-Radio Teardown: stap 4, afbeelding 2 van 3 Audiovox CD-Radio Teardown: stap 4, afbeelding 3 van 3
    • Now, hunt down all the little screws on the motherboard and remove them. There are 4 or 5, so if it doesn't want to move, it's probably being held by a screw or two.
    • Now that all the screws, are gone, slowly lift and remove the motherboard. I say slowly because there are still a few cables attatched to the underside.
    • Disconnect all cables that aren't soldered on.
  5. Audiovox CD-Radio Teardown: stap 5, afbeelding 1 van 3 Audiovox CD-Radio Teardown: stap 5, afbeelding 2 van 3 Audiovox CD-Radio Teardown: stap 5, afbeelding 3 van 3
    • Now that those cables are removed, lift the motherboard up and out... or not.
    • The motherboard is attached to the LCD board via one of those pesky ribbon cables that's soldered on both ends and always seems to be covered in some sticky substance.
    • Lift the motherboard up so you have a good view of the LCD board.
platnicat
44 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 1,339
