Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Asus ZenWatch 3 te repareren, gebruik onze reparatiehandleidingen.
  1. Asus ZenWatch 3 Teardown, Let's begin: stap 1, afbeelding 1 van 1
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: stap 2, afbeelding 1 van 2 Asus ZenWatch 3 Teardown, Band Removal: stap 2, afbeelding 2 van 2
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: stap 3, afbeelding 1 van 1
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: stap 4, afbeelding 1 van 1
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: stap 5, afbeelding 1 van 1
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: stap 6, afbeelding 1 van 1
    • Battery
  7. Asus ZenWatch 3 Teardown: stap 7, afbeelding 1 van 1
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: stap 8, afbeelding 1 van 1
    • Complete disassembly
Reon
141 Reputatie
1 Handleiding geschreven
20 opmerkingen
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - Antwoord
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - Antwoord
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - Antwoord
What should I do if the power button doesn’t work?
MichaelKing10or - Antwoord
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 62
Altijd: 14,586
