Inleiding
A look inside the Arlo Pro 3 Security Camera
Wat je nodig hebt
Features:
2K Video with HRD
Color Night Vision
Integrated Spotlight
2-Way Audio
Weather Resistant
In the Box:
Camera, Battery Pack, USB Charging Cable, and Magnetic Mounting Base
Once the Camera Face Plate has been removed, remove the small rubber gasket on the front with a Spudger Tool. At this point, we get the first look at the electronics that make of up the Arlo Pro 3 Security Camera
Spot Light LEDs
Infrared Light LEDs
Light Detector
LED
Speaker / Siren - ARFALCON R01 BSE <PC> K 1-1 B9804 CB
The microphone on the PCB is held in place with a rubber gasket, and connected via flex cable
To remove the Microphone, use a Spudger Tool to flip up the retention clip that holds the flex cable in place, and gently pop the microphone gasket from the PCB
The microphone rubber gasket can be separated from the Microphone
The Microphone is a Vesper VM1010 Wake-On-Sound MEMS Microphone
There are two more PCBs in the camera face assembly. The Top PCB is held in place via a zero force insertion connector.
A Spudger Tool can be used to remove the Top PCB by gently prying the Top PCB loose near the zero force insertion connector, and working around the outside of the Top PCB prying it loose further with the Spudger Tool
The Siren/Speaker is also connected to the Top PCB and can be unplugged.
Once the Heatsink has been removed, the Top PCB can be inspected. The Top PCB has RF Shielding on both sides
The RF Shielding can be removed using a Dental Pick Took
Pro-tip, if the RF shielding has a small circle indention on it, there is a good chance the shield was snapped in place, and not soldered to the PCB, which makes it easier to remove
One side of the Top PCB appears to be Power and Audio. Three components were crossed on this PCB. One Part was located up under the RF shielding Frame
BQ25898 - I2C Controlled Single Cell 4-A Fast Charger with MaxChargeTM for High Input
TAS2560 - 5.6W Class-D Mono Audio Amplifier with IV Sense
DSP Group D2A3X - Audio DSP
Components on this side of the Top PCB contain the Camera Video Image Processor, RAM, FLASH, and Wireless Communications
Appears to be a video image processor - OA00804-B56G
WiFi Antenna and connector for an u.fl antenna
Battery Connector
Using a Dental Pick Tool, remove the heatsink.
The heatsink is for the PYD1548/7660 Excelites Tech Low Power Motion PIR Sensor. PIR Sensors can be kept cool to improve sensing performance
Other components on this side of the board appear to be for power and control functions
On this side of the PCB, there are two PH00 screws that hold the Camera Lens in place. Remove these screws to release the Camera Lens
The Camera Lens is motorized. There is a control wire and connector for the Camera Lens. Remove the Camera Lens wire from the connector, and pull the Camera Lens free to reveal the 2K QHD Camera Sensor
Components:
2K QHD Camera Sensor - Not marked
2 opmerkingen
My camera fell like 15 feet onto concrete. Now it powers on and syncs, but will no longer actually connect. What most likely broke inside? Thanks
