Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Apple Cinema HD Display te repareren, gebruik onze reparatiehandleidingen.
  1. Apple Cinema HD Display 30" Teardown, Intro: stap 1, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, Intro: stap 1, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, Intro: stap 1, afbeelding 3 van 3
    • Gather your tools (look in the teardown description).
    • You do not specifically need the "64 Bit Driver Kit" I linked, you just need a general screwdriver kit with Torx screwdrivers/bits specifically.
    • The ratchet in the pictures included is not necessary.
    • Lay the cinema display face down on a soft surface in order to not scratch or harm the LCD panel.
  2. Apple Cinema HD Display 30" Teardown, Stand removal pt. 1: stap 2, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, Stand removal pt. 1: stap 2, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, Stand removal pt. 1: stap 2, afbeelding 3 van 3
    • Unscrew the two screws on the sides of the stand where the stand connects to the display.
    • A ratchet may be useful here but isn't necessary.
    • Image 3: Screws remain.
  3. Apple Cinema HD Display 30" Teardown, Stand removal pt. 2: stap 3, afbeelding 1 van 2 Apple Cinema HD Display 30" Teardown, Stand removal pt. 2: stap 3, afbeelding 2 van 2
    • Remove the four Torx screws where the stand attaches to the cinema display.
    • Remove the stand.
  4. Apple Cinema HD Display 30" Teardown, Left side panel: stap 4, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, Left side panel: stap 4, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, Left side panel: stap 4, afbeelding 3 van 3
    • Wedge a putty knife into the plastic side piece, without trying to pry the plastic off yet!
    • Either use the heat gun to heat the plastic piece for about 30 seconds, or use the hair dryer for up to a minute.
    • Carefully use the putty knife to work the plastic side piece off the cinema display. Re-heat the plastic piece again if it doesn't come off with ease.
  5. Apple Cinema HD Display 30" Teardown, Right side panel: stap 5, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, Right side panel: stap 5, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, Right side panel: stap 5, afbeelding 3 van 3
    • Repeat the steps in Step 4.
    • Work carefully when prying this specific side panel off. Be sure to NOT insert the putty knife near the buttons when removing the side panel with buttons (you risk severing the button board cable underneath the plastic piece).
  6. Apple Cinema HD Display 30" Teardown, Panel under right side panel: stap 6, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, Panel under right side panel: stap 6, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, Panel under right side panel: stap 6, afbeelding 3 van 3
    • Remove the four Torx screws.
    • Use a pry tool to remove the secondary side panel.
  7. Apple Cinema HD Display 30" Teardown, Left secondary side panel: stap 7, afbeelding 1 van 2 Apple Cinema HD Display 30" Teardown, Left secondary side panel: stap 7, afbeelding 2 van 2
    • Repeat Step 6 for the left secondary side panel.
    • The screws should be the same length and in the same place as the right side panel.
  8. Apple Cinema HD Display 30" Teardown, Undo latches: stap 8, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, Undo latches: stap 8, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, Undo latches: stap 8, afbeelding 3 van 3
    • Wedge the putty knife in between the metal pieces (arrow in image).
    • Move the metal piece circled green towards the display panel to disengage the clip.
    • Repeat for the identical clip on the opposite side of the display.
  9. Apple Cinema HD Display 30" Teardown, Enclosure removal pt. 1: stap 9, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, Enclosure removal pt. 1: stap 9, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, Enclosure removal pt. 1: stap 9, afbeelding 3 van 3
    • First image: Separate the metal enclosure at the bottom. Use prying tools to undo the retaining clips if needed.
    • Second image: Thread the all-in-one cable out of the hole in the metal enclosure.
  10. Apple Cinema HD Display 30" Teardown, Enclosure removal pt.2: stap 10, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, Enclosure removal pt.2: stap 10, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, Enclosure removal pt.2: stap 10, afbeelding 3 van 3
    • Peel up the tape (shown in the red circle). Then peel up the remaining component off the enclosure.
    • Not shown: Bend the enclosure apart just enough to slip the display panel assembly out of the enclosure.
    • Tip: Use a friend and have them hold the two parts of the enclosure apart while you lift the display panel assembly out of the enclosure.
  11. Apple Cinema HD Display 30" Teardown, All-in-one cable & logic board removal: stap 11, afbeelding 1 van 3 Apple Cinema HD Display 30" Teardown, All-in-one cable & logic board removal: stap 11, afbeelding 2 van 3 Apple Cinema HD Display 30" Teardown, All-in-one cable & logic board removal: stap 11, afbeelding 3 van 3
    • Remove 3 screws holding the all-in-one cable in place (shown in red circles).
    • Remove three more screws (shown in blue circles).
    • Remove 5 more screws holding the logic board intact (shown in yellow circles).
Bijgevoegde documenten
tr121
960 Reputatie
1 Handleiding geschreven
Kid fixers Lid van Kid fixers
Community
186 Leden
256 handleidingen geschreven
8 opmerkingen
Hey thanks for posting this up… is it possible for you to share the LG display panel part number? I want to see if I can find one online.
Julian Wong - Antwoord
This wasn’t my teardown - merely a translation so I don’t know… sorry!
tr121 -
No worries thanks anyway!
Jude Lian - Antwoord
Hi,did you manage to get the panel model number ? And if you did how much was it ?
Stephen paladini -
These use LG Philips LM201W01 monitors, same as the iMac G5 for people looking for the panel information. You can also replace the CCFLs with LEDs for better life and no buzzing.
Naoki's Retro Corner - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 175
Altijd: 7,545
