Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Anker LC-90 Rechargeable Flashlight te repareren, gebruik onze reparatiehandleidingen.
  1. Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: stap 1, afbeelding 1 van 3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: stap 1, afbeelding 2 van 3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: stap 1, afbeelding 3 van 3
    • Unscrew the battery cap
    • Remove battery
    • The cap is heavily tightened from the factory, therefore it may be necessary to use a rubber mat for added grip.
  2. Anker LC-90 Rechargeable Flashlight Teardown: stap 2, afbeelding 1 van 1
    • Unscrew the lens holder as shown in the picture
  3. Anker LC-90 Rechargeable Flashlight Teardown: stap 3, afbeelding 1 van 3 Anker LC-90 Rechargeable Flashlight Teardown: stap 3, afbeelding 2 van 3 Anker LC-90 Rechargeable Flashlight Teardown: stap 3, afbeelding 3 van 3
    • Slide the lens housing down, toward the base, to remove
    • Note that once the lens housing is pushed down the lens and reflector pop out.
  4. Anker LC-90 Rechargeable Flashlight Teardown: stap 4, afbeelding 1 van 1
    • The Anker LC-90 is now tore down
Nick Wolfe
709 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G4, Livingston Winter 2018 Lid van Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 Leden
13 handleidingen geschreven
5 opmerkingen
cannot buy parts or return
JULIA - Antwoord
have an l90 by anker
where can i get parts
seems to need new assembly where u plug in usb
JULIA - Antwoord
Have 3 LC90 flashlight with the same problems, switch stuck & intermittently works! Need 3 replacement cap/switches part #??
Ray Miller - Antwoord
Where can I find a replacement bulb assembly for an anker bolder flashlight?
richard pare sr - Antwoord
Thanks for the information. Took the flashlight battery out and then put in back in; seems to be working great for now!
Steve Moss - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 20
Altijd: 3,967
