Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Amazon Fire Stick 4k te repareren, gebruik onze reparatiehandleidingen.
  1. Amazon Fire Stick 4k Remote Teardown, Heat the remote to loosen the glue.: stap 1, afbeelding 1 van 1
    • Heat it a lot if you are trying to maintain it in working order because it seems the glue on the clasps was very strong. I probably broke mine taking it apart (but it didn't work anyway so I don't know).
  2. Amazon Fire Stick 4k Remote Teardown, Pry it apart.: stap 2, afbeelding 1 van 2 Amazon Fire Stick 4k Remote Teardown, Pry it apart.: stap 2, afbeelding 2 van 2
    • It takes A LOT of force to pry this apart. I'm not sure it's possible without breaking the inside.
  3. Amazon Fire Stick 4k Remote Teardown, Remove the seven motherboard screws.: stap 3, afbeelding 1 van 1
    • Very easy to remove with the #0 phillips screwdriver.
  4. Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: stap 4, afbeelding 1 van 3 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: stap 4, afbeelding 2 van 3 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: stap 4, afbeelding 3 van 3
    • Once the screws are removed, all the pieces come out easily.
Nathan Ruffing
593 Reputatie
2 handleidingen geschreven
Één opmerking
Thanks for the teardown, new firestorm 4k has a couple of screws under the round wheel, but you can pop that off and the remove.
. I used a pair of pliers to just rip off the mic, it is surface mounted and comes away with the pads and remote still works. Small amount of glue on the inside.
Scott - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 55
Altijd: 3,560
