Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Alcatel Onetouch Go Play te repareren, gebruik onze reparatiehandleidingen.
  1. Alcatel Go Play (7048W) Teardown, Lets take a looksie!: stap 1, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, Lets take a looksie!: stap 1, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, Lets take a looksie!: stap 1, afbeelding 3 van 3
    • The Alcatel Go Play 7048W running Android 5.0.2. It advertises water resistance, and expandable memory! The processor is a Snapdragon 410 with 4 cores running at 1.2GHz. The display is 5 inches with a resolution of 720 x 1280. 8 GB internal storage, and 1 GB of RAM.
    • Some other features are 802.11b/g/n wifi and bluetooth 4.1. Not a bad little phone for $200.
    • This device (well two of them) came into my little repair shop from a local phone dealer. Apparently the customers had shoved the SIM cards into the phones without the SIM card tray, then pried them out with tweezers. Now they won't read SIM cards. It all happened before they where even paid for, still in the store. Oh fun!
  2. Alcatel Go Play (7048W) Teardown, How do we get in?: stap 2, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, How do we get in?: stap 2, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, How do we get in?: stap 2, afbeelding 3 van 3
    • On the left, we have a door that exposes the Micro SIM card slot and tray, as well as the Micro SD card slot and tray. The right has power, volume down and up. The bottom sports a Micro USB port, with a door. And the top has a 3.5mm headphone jack (may it rest in peace) with a door.
    • All of these doors are for the water proofing, like many other phones. Reminds me of the Galaxy S5.
    • Taking a iSesmo to the back cover snaps off a few holding snaps around the phone. I do like that sound...
  3. Alcatel Go Play (7048W) Teardown: stap 3, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown: stap 3, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown: stap 3, afbeelding 3 van 3
    • Taking the back off exposes very little. We find the ability to take off the water proofing doors and two little screws. definitely feeling like an S5 now.
    • The screws at the bottom on either side of the charging port are filled in with a hard coating, assuming for water proofing. I had to scrap away at them to access them. I don't think water proofing post repair is going to be a thing.
  4. Alcatel Go Play (7048W) Teardown, It's gettin hot in here!: stap 4, afbeelding 1 van 1
    • Looks like we'll have to go in from the front! That means some heat to melt the adhesive around the screen. Having flashbacks to the Galaxy S5!
    • I'm using a hot plate set pretty low. Alternatively you can use a hot air gun, of iFixits iOpener, or even a hair dryer.
  5. Alcatel Go Play (7048W) Teardown, Waiting.: stap 5, afbeelding 1 van 1
    • Waiting for the hot plate...
  6. Alcatel Go Play (7048W) Teardown, Open Sesame!: stap 6, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, Open Sesame!: stap 6, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, Open Sesame!: stap 6, afbeelding 3 van 3
    • Inserting the iSemamo gets a little gap started, then I can get my pick in there and slide it down and around the entire screen.
    • Remember, if it's hard to separate the adhesive, apply more heat. You do can each side individually. No need to heat the middle, there is no adhesive there.
  7. Alcatel Go Play (7048W) Teardown, Screen is off!: stap 7, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, Screen is off!: stap 7, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, Screen is off!: stap 7, afbeelding 3 van 3
    • Prying slowly and taking care not to rip the flex cable, which is attached to the upper right of device, we can take the screen off.
    • The screen came off easy and the LCD is fine! My flash back to the S5 has ended, for now.
  8. Alcatel Go Play (7048W) Teardown, One connection!: stap 8, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, One connection!: stap 8, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, One connection!: stap 8, afbeelding 3 van 3
    • Looks like one flex connects the screen assembly to the board.
    • Two screws hold down a retention plate that keep the connector in place.
    • Screen is off! Also, with closer inspection of the screen assembly, the glass and LCD are NOT separate. my attempts to separate them, even with a hot plate created a crack in the LCD. If you're looking for replacement parts, best to get it as one.
  9. Alcatel Go Play (7048W) Teardown, Detaching the charging port: stap 9, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, Detaching the charging port: stap 9, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, Detaching the charging port: stap 9, afbeelding 3 van 3
    • Charging port looks pretty easy to detach.
  10. Alcatel Go Play (7048W) Teardown, Screws!: stap 10, afbeelding 1 van 2 Alcatel Go Play (7048W) Teardown, Screws!: stap 10, afbeelding 2 van 2
    • Before we go any further, there are 15 total screws keeping the mid frame in place to the back housing.
    • They are all the same, so no worries getting them mixed up!
  11. Alcatel Go Play (7048W) Teardown, Midframe detachment: stap 11, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, Midframe detachment: stap 11, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, Midframe detachment: stap 11, afbeelding 3 van 3
    • Using my iSesamo pry tools, I easily took the mid frame assembly out of the back housing.
    • Be careful, the charging port comes out at a bit of an angle.
  12. Alcatel Go Play (7048W) Teardown, "Power" to you!: stap 12, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, "Power" to you!: stap 12, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, "Power" to you!: stap 12, afbeelding 3 van 3
    • If I could've, I would've unplugged the battery by now.
    • There is a little bit of Kapton tape over the connector. Then use a plastic pry tool to unhook the battery.
    • Sorry for the different colored images, I switch to my phone camera for some closer images.
    • The battery is a 2500mAH 9.5WH
  13. Alcatel Go Play (7048W) Teardown, Charging port in detail: stap 13, afbeelding 1 van 2 Alcatel Go Play (7048W) Teardown, Charging port in detail: stap 13, afbeelding 2 van 2
    • At this point as well, I can take out the charging port.
    • It reads Go Play USB fpc V00B AKM SBF61H00051B
  14. Alcatel Go Play (7048W) Teardown, Out with the board: stap 14, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, Out with the board: stap 14, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, Out with the board: stap 14, afbeelding 3 van 3
    • A quick discount of the daughter board flex and antenna cable releases the board from the mid frame.
  15. Alcatel Go Play (7048W) Teardown, Daughter board out!: stap 15, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, Daughter board out!: stap 15, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, Daughter board out!: stap 15, afbeelding 3 van 3
    • A wee bit of heat to melt the adhesive, and the daughter board is almost out, looks like we need to take the battery out first.
  16. Alcatel Go Play (7048W) Teardown, Out with the battery: stap 16, afbeelding 1 van 2 Alcatel Go Play (7048W) Teardown, Out with the battery: stap 16, afbeelding 2 van 2
    • A simple prying to the battery with a plastic pick gets it right out. Remember to use plastic, we don't need a Note 7 here.
  17. Alcatel Go Play (7048W) Teardown, Out with the daughter board, this time I mean it: stap 17, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, Out with the daughter board, this time I mean it: stap 17, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, Out with the daughter board, this time I mean it: stap 17, afbeelding 3 van 3
    • Some careful lifting of the board and the flex cable gets the board off the mid frame.
  18. Alcatel Go Play (7048W) Teardown, The board and more: stap 18, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, The board and more: stap 18, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, The board and more: stap 18, afbeelding 3 van 3
    • We have the board out, time to take the proximity sensor, front facing 5MP camera, and rear facing 8MP camera out. All are simple modular parts.
  19. Alcatel Go Play (7048W) Teardown, This is so "Boring": stap 19, afbeelding 1 van 3 Alcatel Go Play (7048W) Teardown, This is so "Boring": stap 19, afbeelding 2 van 3 Alcatel Go Play (7048W) Teardown, This is so "Boring": stap 19, afbeelding 3 van 3
    • I went ahead and took off all of the shielding of the board, front and back.
    • It also looks like the SIM card port reader is on the board. I have a feeling there is little hope for this as a repair.
  20. Alcatel Go Play (7048W) Teardown, Yup, no good: stap 20, afbeelding 1 van 1
    • Looks like there is little hope for this. For those of you who may not know, that little part there to the left is the reader, it came right off, and has some of the solder pads attached, they are those pinkish copper looking things on the edges and in the middle.
    • Since it pulled the pads off in the original damage, and there are no schematics, I'm not going to even try and run jumpers or rebuilding the pads.
Jeff Caauwe
1.206 Reputatie
2 handleidingen geschreven
JCow Repairs LLC Lid van JCow Repairs LLC
Business
1 Lid
8 opmerkingen
Should say Alcatel Onetouch Go Play 7048W
Gabe - Antwoord
Right you are, thank you!
Jeff Caauwe -
Search engines pick up easier when you include the full name. My experience anyhow, I mean you no disrespect.
Gabe -
could you do an ifixit and tell us the ICs and stuff
Tim Reimer - Antwoord
When I get a chance, sure!
Jeff Caauwe -
So far there isn’t any IC Identifications yet, but I may be able to do some (and possibly even more) if there are clearer pictures.
CChin -
Cuanto por el flex de carga
Edgar - Antwoord
By any chance, can you attach clearer pictures of the boards please?
CChin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 4,470
