Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je AWEI BT Earbuds te repareren, gebruik onze reparatiehandleidingen.
  1. AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: stap 1, afbeelding 1 van 2 AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: stap 1, afbeelding 2 van 2
    • Remove Earbud Cushion
  2. AWEI BT Earbuds & Receiver Teardown, Secure Earbud for Separation: stap 2, afbeelding 1 van 1
    • Secure Earbud End (eg:Vice)
  3. AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: stap 3, afbeelding 1 van 2 AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: stap 3, afbeelding 2 van 2
    • Using Pliers Gently Twist & Pry Away Sections, Do Not Twist more than 3-4mm
  4. AWEI BT Earbuds & Receiver Teardown, Inspect Separated Earbud Internal Wiring: stap 4, afbeelding 1 van 1
    • Inspect Earbud Wiring
  5. AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: stap 5, afbeelding 1 van 3 AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: stap 5, afbeelding 2 van 3 AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: stap 5, afbeelding 3 van 3
    • Using a small pick or pry tool, separate Receiver Housing. Each side is secured by 3 small fragile tabs. Use the space near the micro USB opening & carefully pry to separate the 3 tabs on the opposite side.
  6. AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: stap 6, afbeelding 1 van 3 AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: stap 6, afbeelding 2 van 3 AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: stap 6, afbeelding 3 van 3
    • Carefully Separate the PCB to inspect the headphone's left & right earbud wiring. Cleaned up any broken connections by de-soldering, re-tinning wires & re-soldering to the PCB. Each side is labeled L + L - and R + R - the colored wire is positive and the bare wire is negative.
    • Assemble Unit in reverse order.
fugitiveALiEN
188 Reputatie
1 Handleiding geschreven
My Techno Guy Lid van My Techno Guy
Business
1 Lid
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 28
Altijd: 1,594
