Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
PDF manual here: AGPTEK A02 Manual
Deze demontage is geen reparatiehandleiding. Om je AGPTEK A02 te repareren, gebruik onze reparatiehandleidingen.
  1. Remove the microSD card, if present. You can use a flat side of a spudger
    • Remove the microSD card, if present. You can use a flat side of a spudger
  2. With a Pick, insert the tool and split the two parts that make the shell of the mp3 player Use Jimmy, if the pick is too flexible for you
    • With a Pick, insert the tool and split the two parts that make the shell of the mp3 player
    • Use Jimmy, if the pick is too flexible for you
  3. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  4. Remove 3 screws with a #00 Philips screwdriver Remove 3 screws with a #00 Philips screwdriver Remove 3 screws with a #00 Philips screwdriver
    • Remove 3 screws with a #00 Philips screwdriver
  5. Remove the switch with the shape of a spudger
    • Remove the switch with the shape of a spudger
  6. That's all. The screen is welded and coated with glue. command bottons usb port
    • That's all. The screen is welded and coated with glue.
    • command bottons
    • usb port
    • the switch
    • SD card holder
  7. Full IC Identification: Predicted Block Diagram is on the 2nd image.
    • Full IC Identification:
    • Predicted Block Diagram is on the 2nd image.
    • You may need to enlarge it to view the text.
Stefano De Rossi
218 Reputatie
1 Handleiding geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 44
Altijd: 1,323
