Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je A.C.Ryan PlayOn!HD te repareren, gebruik onze reparatiehandleidingen.
  1. A.C.Ryan PlayOn!HD Teardown, A.C.Ryan PlayOn!HD Teardown: stap 1, afbeelding 1 van 2 A.C.Ryan PlayOn!HD Teardown, A.C.Ryan PlayOn!HD Teardown: stap 1, afbeelding 2 van 2
    • The ACRyan PlayOn HD with remote control.
  2. A.C.Ryan PlayOn!HD Teardown: stap 2, afbeelding 1 van 2 A.C.Ryan PlayOn!HD Teardown: stap 2, afbeelding 2 van 2
    • The rear panel with the necessary connectors.
  3. A.C.Ryan PlayOn!HD Teardown: stap 3, afbeelding 1 van 2 A.C.Ryan PlayOn!HD Teardown: stap 3, afbeelding 2 van 2
    • The location of the 2.5 HD is at the bottom of the case.
  4. A.C.Ryan PlayOn!HD Teardown: stap 4, afbeelding 1 van 3 A.C.Ryan PlayOn!HD Teardown: stap 4, afbeelding 2 van 3 A.C.Ryan PlayOn!HD Teardown: stap 4, afbeelding 3 van 3
    • The small motherboard with the USB and IR receiver PCB.
Vincent Tay
101 Reputatie
1 Handleiding geschreven
4 opmerkingen
Hi,
I have a somewhat different problem my remote broke and before I buy a new one I want to try fixing mine there are two components missing which I could easily replace but I don't know the ratings or model numbers of the components. So if anyone could send me pictures of the components that would be awesome.
mpinnie - Antwoord
Have you fix it? Or you had threw it away?
Bee B - Antwoord
Hi
the ac Ryan is not being recognised by my laptop through USB Connection.
Is there any remedy?
Cyril Kevin - Antwoord
Hi! Where can I buy the remote control of AC Ryan
Roberto Albino - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 3,397
