« Terug naar alle verhalen
Restored my MacBook!
wvoutlaw2k -
MacBook Unibody Model A1342
MacBook Unibody Model A1342 Battery Replacement
5 - 10 minuten
Easy
Mijn probleem
Recently my MacBook was reporting that my battery needed to be replaced. After researching for solutions on Google, I came across this site, and I found what battery I needed and what tools I needed to perform the battery replacement.
Mijn oplossing
The repair took very little time! All you do is open the bottom MacBook case with a #00 Phillips head screwdriver (had one left over from when I upgraded my RAM), remove the case, use the spudger tool to unplug the battery from the logic board, the tri-wing screwdriver to remove the three tri-wing screws (you'll have to use the spudger to peel back the sticker covering the leftmost screw), use the #00 Phillips screwdriver to remove three small screws which secure the battery to the bottom of the Macbook, remove the battery, install the new battery, put all the battery screws back in, plug the battery terminal back into the logic board, put the case back on, screw the case screws back in, and turn it back on.
Mijn advies
If you have any battery issues with your MacBook, go with this solution!
Spudger afbeelding
Spudger
$2.99
Tri-point Y1 Screwdriver afbeelding
$12.99
0 Opmerkingen
