Ga door naar hoofdinhoud
« Terug naar alle verhalen
Saved a bundle
ovenwally -
Mijn probleem
Fixed income - need to save money, problems were very annoying and needed to be fixed.
Mijn oplossing
Replaced battery, trackpad. and DC input board. Works like a charm
Mijn advies
Order spudger and correct screwdrivers along with parts. Work under a bright light, preferably on a large table to lay out all the screws in disassembly groups in order of correct hole pattern. Work slowly and use a magnifying glass and hand held light source to look up close at connectors before disconnecting, read instructions carefully, don't miss a step. Use sticky tape to grab ribbon cable for re-connect. Look at picture frames in reverse sequence for reassembly.
Tri-point Y1 Screwdriver Afbeelding
$5.49
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 42
