Ga door naar hoofdinhoud
« Terug naar alle verhalen
So far, so good!
bobball -
iPhone 4S
iPhone 4S Battery Replacement
10 - 30 minuten
Moderate
Mijn probleem
The battery or charging software in the iPhone 4s became unreliable. It would drop from 30 percent to zero and shut down. The new battery seems to have ended the problem.
Mijn oplossing
The installation was easy. Other than a couple of minor spooks.
Mijn advies
Fixing the loose part with tweezers was delicate, and if I recall correctly, I needed to consult other sites to be sure of the orientation of that part. And the ribbon cable from the battery seemed slightly misaligned with the connector once the battery was in place. I connected, then placed the battery.
iPhone 4S Battery Afbeelding
iPhone 4S Battery
$16.99
Magnetic Project Mat Afbeelding
$19.95
0 opmerkingen
Voeg opmerking toe
