Replaced 500g Drive in 24" 2.4 iMac that failed SMART status with 1TB
Mijn probleem
Failed SMART status, Apple no longer supports this model.
Mijn oplossing
It went well, except the ambient temperature sensor for the 24 iMac run around the entire monitor housing from top to bottom. The previous mac installer had nearly ruined the cable, when I installed this drive, one of the top screws for the metal bezel went through the sensor cable and shorted the machine and threw the heat sensors off, fans went on machine shut down. I soldered the broken wire (one of four) and it's back up. Also ordered a replacement for the future if there's a problem from a supplier here in New York.
Mijn advies
I think you guys should have a sterner warning for people about this LCD temp sensor. I had it in the proper place, the problem was the screw punctured the cable housing when screwed in, it's happened to many others via Apple support forums. Here's the part number for when someone has this issue if they are unable to repair the cable: Part: iMac Intel Aluminum 24" LCD Display Temp Sensor Cable .works in: iMac (24-inch Mid 2007)iMac (24-inch Early 2008) 2.4/2.8/3.06GHz.Apple part#922-8236.60 and here's a link to the support forum discussion: https://discussions.apple.com/message/24...
0 opmerkingen
