Ga door naar hoofdinhoud
« Terug naar alle verhalen
Directions Great.. Can't believe it is fixed.
theandromedan -
MacBook Pro 15" Core Duo Model A1150
MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement
Very difficult
Mijn probleem
My daughter's laptop LCD display got broke because my other daughter decided to through the remote and hit and broke the screen.
Mijn oplossing
The repair went without a hitch. I took it nice and slow. The only problem I had was with the spudger and using it to separate the pieces.
Mijn advies
Get the spudger. It is good for keeping things separated and putting the connectors back on. Get a set of small screwdrivers and use one of the larger screwdrivers to do the separating of the screen and the LCD display.
Spudger Afbeelding
Spudger
$3.99
T6 Torx Screwdriver Afbeelding
T6 Torx Screwdriver
$9.99
Phillips #00 Screwdriver Afbeelding
$5.49
MacBook Pro 15" (Models A1150/A1211) LCD Panel Afbeelding
$199.99
0 opmerkingen
Voeg opmerking toe
