Mijn probleem
Since i used SSD, dont want to hear about HDD for OS and aplications.
Mijn oplossing
Was easy, i was a little nervous, but everithing go well except...
Mijn advies
DON'T, DON'T, DON'T try to format the SSD while you're in the recovery mode, do it before you recover the OSX, if you do that the system recognizes the hard drive and the SSD as a broken Fusion Drive and will detroy all your data, If you just donĀ“t see this on time, just disconect the HDD, recover your MAC mini into the SSD, then connect again the HDD and format it with the HDD utility. Hope this helps someone.
0 opmerkingen
