« Terug naar alle verhalen
Went from no-clicky to clicky in about an hour!
tom -
iPhone 4S
iPhone 4S Power and Sensor Cable Replacement
2 - 3 uren
Difficult
Mijn probleem
My power button was stuck down - no amount of pressure would make it work. I read in the notes that the problem was likely the power cable, not the button itself, so that's what I ordered.
Mijn oplossing
It took about an hour - I was nervous, first time, you know. The directions and photos were excellent. Even the warnings about things that might get lost or damaged in the process.
Mijn advies
Re-installing the cable was tricky. It ships flat but has to be contorted pretty good to get into place. Go ahead and buy a new earpiece - the sticky gets undone during disassembly. I had to plug in the cable then roll it over to plug in the bracket and slide the ear piece into the loop of ribbon. It was awkward but works fine. I labeled a piece of paper with the screw sizes - there are about 8 different ones. When I took one out, I taped it to the paper. Reassembly was a breeze because I was confident I had the right screw for each spot.
Thanks y'all @ifixit, saved me some coin and got my phone back in business! Tom
iPhone 4S Power and Sensor Cable afbeelding
$19.99
Spudger afbeelding
Spudger
$2.99
0 Opmerkingen
