Verizon iPhone 4 - Extremely Fast and Easy Battery Replacement!
thunterc -
Mijn probleem
Two year old iPhone 4. Would not hold a charge for longer than half of a normal day of normal usage. Heavy usage required two charges during the day and over night, just to maintain the phone usability. Full charge to 99 percent usually took about an hour on House charger and 30 minutes in auto charger. These were my only problems with the Verizon iPhone 4.
Mijn oplossing
My repair followed the Verizon iPhone 4 Repair Manual exactly.
I read through the repair steps 3 or 4 times ahead of time, so once I got my Battery and the Liberation Kit, I was already very familiar with the repair procedure.
My repair went extremely easily and only took me about 7 minutes from start to finish!
This repair was exactly like the Verizon iPhone 4 Repair Guide in ALL ways. There was no additional steps to perform and no surprises or missing steps from the Repair Guide to perform.
This repair is extremely fast, extremely easy, and requires very little knowledge to perform completely and competently.
There were only 3 Screws to remove and only 3 a screws to replace to complete this Verizon iPhone 4 Battery Replacement Repair! Again, the total repair time for this repair took me about 7 Minutes!
Thank iFixit for making this Verizon iPhone 4 Repair extremely fun and extremely easy!
The Pictures in the Verizon iPhone 4 Repair Guide are 100 Percent accurate. There is no need to add additional pictures beyond those provided in the Repair Guide.
Mijn advies
Keep the 2 Screws for the Case Opening seperate from the single Battery Ribbon Connector Screw, so that these 3 Screws all go back in their original locations. I would also be careful not to allow these Screws to enter into the Dock Connector or the internal iPhone Case, as they are being removed and inserted. These all seem to be magnetized, so this shouldn't be a problem, as they are magnetically attracted to the Screw Driver tip. Also, I would work in a clean environment, lay out a white paper towel or a small dish for the 3 Screws, and wash and dry both hands thoroughly before starting the repair procedure.
0 Opmerkingen
