Ga door naar hoofdinhoud
« Terug naar alle verhalen
Airport card
dangold -
Mijn probleem
Airport card dropped signal
Mijn oplossing
Challenging because of the small screws.
Mijn advies
Install the left-hand screw on the Airport card and then connect the antenna connections. Don't install the right-hand screw until you've made the right-hand antenna connection, because that leaves you much more room to work.
Spudger Afbeelding
Spudger
$3.99
0 opmerkingen
Voeg opmerking toe
