Mijn probleem
Power button got stuck, couldn't press down any longer plus battery was dying.
Mijn oplossing
Replaced the battery, the power button, and the sensor cable. Followed all the directions as carefully as I could. Everything works fine!
Mijn advies
Be careful, take your time, I got the Pro Tech Tool kit and screw mat for it. Also, take good pictures of your stuff every step of the way you can, at one point as I was putting the logic board back in, the rubber bumper on the end of it that protects the cables from wear and tear, fell out. I didn't know where it came from, so I looked at a pic I took during disassembly and luckily found where it fit.
0 opmerkingen
