Mijn probleem
the fan began to make so much noise, i installed the software smcfan to saw whats was going on and i realized the left fan was dead 0 rpm
Mijn oplossing
perfect, i printed the guide and step by step i changed the fan, so easy
Mijn advies
Only be carefull by pulling the plugs, better use the Spudger if you can.
When remove the dead fan, clean the grille you will see before installing the new one
0 opmerkingen
