Ga door naar hoofdinhoud
« Terug naar alle verhalen
Rescuing my mac from a coffee spill
ocab -
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 15" Unibody Mid 2010 Upper Case Replacement
2 - 3 uren
Difficult
Mijn probleem
I spill a little bit of coffee over the keyboard of my MacBook Pro and some keys stop responding. So since It was my fault I decided to do the repair by my self. So I visited the ifixit website, did a little research, order the lower case and follow the guide.
Mijn oplossing
It took me like 1 hour to complete the task but using the ifixit guide made it very simple. I really want to thank you ifixit for developing a guide that was very straight forward, with excellent pictures, great notes and important warnings. The way the guide was design it really shows that you took the time and effort to made it as simple as possible.
Mijn advies
Get a bunch of plastics cups. For each step that requires removing screws or any other small piece, I wrote the step number on the plastic cup and put the pieces inside, that way you won't miss any screw and it will be easier to follow the guide backwards to reinstall all the components.
Spudger Afbeelding
Spudger
$3.99
T6 Torx Screwdriver Afbeelding
T6 Torx Screwdriver
$9.99
Phillips #00 Screwdriver Afbeelding
$5.49
Tri-point Y1 Screwdriver Afbeelding
$5.49
MacBook Pro 15" Unibody (Mid 2010) Upper Case Afbeelding
$49.99
0 opmerkingen
Voeg opmerking toe
