Mijn probleem
By accident my keyboard got wet, and some keys stopped working, It became really annoying not to be able to write correctly, so I decided to fix it.
Mijn oplossing
The repair went really smoothly, having gotten the tools you recommended and the parts needed, the instructions where really helpful tho there where two things I wold like to comment about, one is that in the tools list I did not see that there was the need of a philips screw driver of 1.6 mm, tho it was not a big problem since I had one at home, just a comment for future clients. The second is that there is a step missing on the instructions, its about removing the battery, again this was not problem for me since its easy to do, but the instructions would be perfect if they did not missed this step. Thank you tho, my computer is now working 100% I will gladly use your website and store again if necessary.
Mijn advies
Simply follow the steps carefully and you shouldn't have a problem.
0 opmerkingen
