Ga door naar hoofdinhoud
« Terug naar alle verhalen
Install SSD in late 2009 27" iMac
ben -
Mijn probleem
No problem -- I just wanted to upgrade to an SSD in the optical bay.
Mijn oplossing
The iFixit guide has you disconnecting and removing the display before getting to the optical drive. Halfway through I realized that that was a bit more work than i wanted to deal with and that there was enough room to get to the bay without removing the entire display...so that's what I did.
Mijn advies
Use your head when following the guides. They're good, but don't be afraid to examine what it is you're actually trying to do.
Spudger afbeelding
Spudger
$3.99
Tweezers afbeelding
Heavy-Duty Suction Cups (Pair) afbeelding
$14.99
Anti-Static Wrist Strap afbeelding
$7.99
TR10 Torx Security Screwdriver afbeelding
$6.99
0 Opmerkingen
Voeg opmerking toe
