« Terug naar alle verhalen
Once Desperate - Now Delighted!
LadyPendragon -
MacBook Core Duo
MacBook Core Duo Hard Drive Replacement
5 - 30 minuten
Easy
Mijn probleem
I love my MacBook Pro 15 and carry it everywhere! I took it back home to Alaska and on my return to the states, it received a few rough bumps and a hard slam from an airline baggage cart. I did not realize the damage until later.
Now the OS would stall and not open correctly and when I used the emergency techniques with APPLE, it still would not reinstall the OS properly. APPLE recommended shop inspection from a list of local dealers. I turned to FIXIT.
Mijn oplossing
Two years back, I successfully replaced a hard drive and installed a super drive into my other Mac G4 and was proud I did well and it all worked wonderfully. I went to the website, used the simple easy instructions on identifying properly the laptop I have and bingo! I was matched with several choices. I went for the biggest - a 750 - quite a step up from the 160 I had currently had.
I did not take note of the time it took to install my hard drive as it went so easy and quick, before I knew it I was ready to reverse my steps and put my laptop back together. It did not take me more than a couple of hours, that I do know. I love the feeling of accomplishment – thanks to FIXIT on my side, I can do anything I need.
Thanks, FIXIT.
Mijn advies
Proper tools make a job go easier!
I decided to order the hard drive upgrade kit complete with the tool set. To top it off, I still remember chasing mini screws on the floor from a jostled sheet of paper years before, so I also ordered the PRO magnetic pad with additional cut outs on the back, giving me a choice as to which side I wanted to use.
Trust me, having the variety of tool tip bits and the magnetic board you can lay your tips on next to the corresponding screws makes a difference. The board is also a dry board so you can make ID notes with the dry erase pen that comes with it.
You get what you pay for and IFIXIT will guide you to success!
Magnetic Project Mat afbeelding
$19.99
0 Opmerkingen
Voeg opmerking toe
