Ga door naar hoofdinhoud
« Terug naar alle verhalen
Why are BOTH MacBooks acting badly?
georgiaruocco -
MacBook Core 2 Duo
MacBook Core 2 Duo Battery Replacement
1 minuut
Very easy
Mijn probleem
I was forced to as one laptop would freeze and when it did work, it could not recognize USB ports due to lack of power.
On laptop #2, it was the battery that seemed to be growing. I have heard of swollen batteries and decided to get a new battery.
So fix it or loose it!
Mijn oplossing
Easily. The first check is always the wires...clearly, the power adapter from wall to laptop #1 was cracked.
Laptop #2 was swollen and all I needed was a coin to open and replace the battery.
Mijn advies
BOTH LAPTOPS ARE HAPPILY WORKING.
Try it yourself. You might learn something! You can always call in an expert and get your problem fixed...
MacBook Replacement Battery afbeelding
$79.99
0 Opmerkingen
Voeg opmerking toe
